Anyone know of a speed sleeve and seal number for the manual steering box?
Discussion in 'General IH Tech' started by TheScoutMaster, May 16, 2018 at 3:41 PM.
  1. TheScoutMaster
    TheScoutMaster High Wheeler
    Aug 1, 2002
    2,124
    34
    70 Miles North of Hell
    For a 1974 SII? Seems I have a groove on the shaft and it is leaking fluid. Thanks.
  2. 1975IH200
    1975IH200 High Wheeler
    2,441
    127
    SKF Speedi-Sleeves are identified by the diameter of the shaft that they are to be installed onto.
    Do you have the shaft diameter measurement??
    if so, go online and go to the SKF Speedi-Sleeve website and view their online catalog to find your answer.
    www.skf.com
    The seal p/n would be the same as the original P/N. It is a Saginaw unit.
  3. walkersscout
    walkersscout High Wheeler
    Oct 5, 2005
    1,184
    108
    AZ
    Just replacing the seal will likely solve the issue so long as the bearings are still in good shape.
  4. Dana Strong
    Dana Strong Y-Block King
    3,597
    465
    Another possibility is to clean the shaft well using appropriate solvents, perhaps roughen the immediate surrounding surface (edges) with coarse sandpaper, and apply some metal-filled epoxy, e.g. This. While soft, wrap with thin plastic (e.g. thick Saran wrap or plastic bag) to give a flat, smooth 'original' surface. Or, carefully file and polish when hard to restore original dimensions.
