Another 1210 brake/axle question.
Discussion in 'The Truck Stop' started by 1977 SS Deuce, Jul 4, 2019.
  1. 1977 SS Deuce
    1977 SS Deuce Farmall Cub
    Jul 7, 2008
    252
    Joliett,PA
    I want to change my axles in my 1210 to chevy axles for the disc brake setup. What year chevy axles should I be looking for? I want to put 3/4 ton axles back in. Thanks for the help
  2. Jeff Jamison
    7,540
    1,018
    what gears are your axles now?
  3. 1977 SS Deuce
    Jul 7, 2008
    252
    Joliett,PA
    I found what chevy axles I need. from years 73-87. As far as gears the tag is not on the dif cover. I am looking at line set ticket anything I can tell is 3.54 gr. Were else would I be able to find out?
  4. jeff campbell
    15,330
    1,491
    Pull cover off. It will be on the edge of ring gear.
  5. 1977 SS Deuce
    Jul 7, 2008
    252
    Joliett,PA
    Thanks Jeff. When I get a chance I will have a look. Now if I go with the different axles should I go with the same gears? My truck is a 345 auto and I don't haul anything with it. Or go off road. I just take it our for cruises. Thank you
  6. Jeff Jamison
    7,540
    1,018
    Gears shouldn't matter if its just a cruiser.I asked on the gears as my travelalls rear is on its way out so if yours was the same,I might be interested,mines 373
  7. 1977 SS Deuce
    Jul 7, 2008
    252
    Joliett,PA
    Thanks Jeff. If I decide to go the chevy way I will let you know. Im still kicking around just switching it to 2wd. Have to figure out what way I want to go.
