AMC 232 - one cylinder out of round?
Discussion in 'General IH Tech' started by Evan McGinnis, Mar 24, 2020 at 7:14 PM.
  1. Evan McGinnis
    Evan McGinnis Farmall Cub
    Apr 15, 2018
    Tucson, AZ
    1971 800B w/ AMC 232
    I've pulled the pistons from my engine today. 5 of the cylinders and pistons look fine. On cylinder #6, however:
    The piston had a broken ring
    The conrod bearing was damaged.
    The piston itself looks OK; no damage to the skirt, just the same level of wear I see on the others.
    The cylinder differed by .0049" when I did a roundness measurement (I will do taper tomorrow. The others were all below .003")
    The manual states that .003" is the limit. How concerned should I me with this?
    Full disclosure here -- I am not particularly adept at doing these measurements, so this may also be operator error.
    Thanks,
    -Evan-
  2. WRENCH MAN
    Dec 24, 2004
    4,280
    128
    Eugene Orygun
    What are you using to measure the cylinders with?
  3. Evan McGinnis
    Apr 15, 2018
    Tucson, AZ
    A telescoping gauge and a micrometer
  4. WRENCH MAN
    Dec 24, 2004
    4,280
    128
    Eugene Orygun
    That is rather minimal wear for an AMC six, has it been rebuilt already?
    You can probably cut the ring ridge out and run it, I helped one of the guys at work overhaul his 4.0 in his Jeep, it was so sloppy that I had to knurl his pistons for him!
    I find snap gauges are a PAIN to get consistent readings with!?, I have a dial bore gauge to measure cylinders with.
  5. Joe Hurley
    Joe Hurley Farmall Cub
    Aug 6, 2018
    100
    You are relatively lucky if you have a broken ring and the cylinder doesn't have and deep gouges. The broken ring and spanked bearing would indicate a detonation issue. I would measure the lobes of the cam on that cylinder vs the rest.
  6. Evan McGinnis
    Apr 15, 2018
    Tucson, AZ
    It does not seem to have been overhauled in the past. Yes, i did consider getting a bore gauge, and I now regret going the way of the telescoping gauges. I don't get consistent results with my (probably) poor technique.
  7. Evan McGinnis
    Apr 15, 2018
    Tucson, AZ
    Unfortunately, I'm trying to do all of this with the engine in place. And it gets worse for me -- the main bearing I examined (nearest that cylinder) had some deep gouges/grooves. so I will need to replace those as well, looks like.
