Alternator Replacement for SD33T
Discussion in 'Diesel Tech' started by virtualpj, Jun 20, 2018.
  1. virtualpj
    virtualpj Farmall Cub
    Feb 2, 2018
    Hi all,
    The alternator on my '80 Turbo Diesel isn't holding a charge anymore, so I need to replace it. All the options I see out there don't include the attached vacuum pump, though. Am I able to just get a replacement alternator and bolt it up to the existing vacuum pump?
    I'm open to other bolt-on suggestions as well. I know a lot of folks have converted to Hydroboost brakes and then are using whatever alternator they want, but that's more of an undertaking than I'm willing to do at this point. I'd like to get 'er back on the road sooner rather than later.
    Thanks in advance!
  2. tinker
    tinker Farmall Cub
    Aug 16, 2003
    339
    Berkeley CA
  3. virtualpj
    Feb 2, 2018
    Thanks so much, Tinker. Turns out the alternator is ok, and it’s the voltage regulator that is shot, so I have a new one on the way. Seems as though I’m going to have to modify it to work based on my searches here, but should be up and running again soon.
    Thanks for the leads above. Seems like if I do have to replace the alternator it’s gonna be a project regardless of what I choose.
  4. RinTX
    2,212
    731
    Yeah. I think if I ever have to go down this road - I’ll separate the alternator and vacuum and install an electric vacuum pump.
    Either that or hydroboost
  5. nfbeckman
    nfbeckman Farmall Cub
    Aug 3, 2008
    79
    arlington
    I just ordered a 110amp hitachi w/vacuum pump for an Isuzu NPR. I'll do a write up when I get it in. Looks pretty straight forward and is internally regulated.
    virtualpj likes this.
  6. David Dixon
    David Dixon High Wheeler
    Nov 19, 2003
    1,060
    Bath, Maine
    I have a vague recollection that there is a slightly different mounting bracket to fix the newer hitachi to the SD33, but the old one can be modified to make it fit, or a new one fabbed. It's not a complicated bracket.
    If you get stuck let me know, I *might* have an extra bracket lying about, but I think I only have one and its in use.
    -David
  7. nfbeckman
    Aug 3, 2008
    79
    arlington
    Thanks you! Do you recall if it takes the original belt or will a different length be needed?
  8. David Dixon
    Nov 19, 2003
    1,060
    Bath, Maine
    It has been a very long time since I installed one, but I remember it coming with a suitable pulley already on it, and that it fit in the same location - drivers side between block and power steering pump - with same belt. I think the one I have is 60 amps ISH, but I expect that it will be in the same case, ie same size, as the one you get.
    I have a parts truck that came with AC and had a different layout with different belts. Not sure how that one would go.
  9. shades
    shades Farmall Cub
    Oct 15, 2003
    74
    7
    Brighton, Co
  10. shades
    shades Farmall Cub
    Oct 15, 2003
    74
    7
    Brighton, Co
    if you upgrade your alternator to a larger amperage output you MUST add a SHUNT so all those amps don't go thru your dashboard.
    Run a wire from your alternator directly to your battery to pull some amps away from your dashboard gauge which cannot handle the larger amps.
    I have run this way for years with no issue using the hitachi alternator that has the vacuum pump.
