Alternator rebuild
Discussion in 'Diesel Tech' started by Tony Lopez, Oct 14, 2001.
  1. Tony Lopez
    Tony Lopez Farmall Cub
    Oct 12, 2001
    Paso Robles
    A while back on th old diesel talk, someone needed to rebuild thier alternator, and I think John gave a place to get it rebuilt for relatively cheap. But I cant find the old archives. Anyone remember where that was? This is for my friends '77 SD33.
    Thanks,
    Tony Lopez,
    Paso Robles, CA
  2. John Donnelly
    Mar 5, 2001
    13,953
    33
    Woodburn, Oregon
    Tony,
    Any good alternator rebuild shop should be up to the task, The cost is usually less than $100.00 for bearings, brushes, testing, and cleanup.
    If you can't find someone locally, let me know, I will tell you how to ship it to me, I have a shop here that will do it. Figger a week turn-around from reciept of the alternator.
    Keep on Dieselin',
    John Donnelly
  3. Dave Nuenke
    Dave Nuenke High Wheeler
    Oct 17, 2001
    1,276
    Newell, SD
    Tony,
    Another suggustion that Eldon has had good success with is to convert to a standard delco alternator and then use a small electric vacume pump to power the brake booster. A delco alternator can be had for $50-60 locally, and if I remember right the pump is only about $20, probably cheaper still at the junkyard. I think an early 80's escort was the specific application that had been tried. The delco alt is generally more hardy than the Hitachi, puts out more voltage, and is readily availible just about anywhere in the country.
