Advice for purchasing
Discussion in 'General IH Tech' started by Humam1953, Feb 7, 2019.
  1. Humam1953
    Humam1953 Farmall Cub
    Feb 7, 2019
    I have the opportunity to buy a 1977 Scout II Traveler with a 345, less than 30k miles, from a trusted person. He replaced radiator, hoses, tires, etc. However, the car was sitting since 1991 in a garage, not being used since. The engine runs ok as much as I can tell. However, should I be concerned that the cylinders have rust from the piston rings? Any other concerns? Thanks.
  2. winchested
    winchested High Wheeler
    2,894
    981
    If it runs and the compression is good it's fine. Any engine sitting that long is going to need to run a while to re seat the rings.
    Other than the color being terrible that thing is mint!
    Sent from my SM-G870W using Tapatalk
  3. Humam1953
    Feb 7, 2019
    Thanks, what compression values I should look for?
  4. Jeff Jamison
    7,229
    839
    It would be best if you posted this in the general IH tech section,you are posting in a parts vender area( anything scout is a dealer)
  5. MrKenmore
    MrKenmore Y-Block King
    3,038
    904
    I think if you can grab that for under $14,500 I would care what the engine was up to! LOL! Of course you'll need to do a complete run through. This will include brakes, steering, diff fluid, plugs, wires, all the normal stuff. It's running now? You can always do a compression test. Looks like a great opportunity. Best of luck.
