AC Parts Worth Keeping?
Discussion in 'General IH Tech' started by TheGoldenGreek, Nov 9, 2019.
  1. TheGoldenGreek
    TheGoldenGreek Binder Driver
    May 28, 2003
    978
    Loudoun County, VA
    Hey all,
    I'm cleaning out my garage. I have an AC Condenser, AC Compressor, and what I think is an orifice tube. Could these things be worth keeping? I think they are parts of an R-12 set up. I don't know if they are serviceable, the AC never worked and when I pulled the engine out 10 years ago this stuff never went back in. I would like to put AC in it, but might be simpler to start with a modern system.
    Thoughts?
  2. winchested
    3,050
    1,084
    York compressors work As good air compressors for on board air. I wish I Had kept mine.
  3. jeff campbell
    15,010
    1,348
    Dont junk none of it.somebody needs it !
  4. Mark Aycock
    Mark Aycock High Wheeler
    Jun 3, 2004
    1,468
    218
    Houston,Texas
    I rebuilt my system last year with a Rockauto compressor, clutch, and thermal expansion valve.
  5. INT77345
    INT77345 Farmall Cub
    Feb 3, 2009
    295
    47
    DENVER
    the condensor is worth keeping, i had a hard time finding one......
  6. jtorre4272
    jtorre4272 High Wheeler
    Nov 19, 2014
    1,709
    664
    Dearborn, MI
    Normally I’d recommend keeping this stuff but everything on your list you can get new and improved. The compressor can be replaced with a brand new Four Seasons York style exactly like original, including clutch. you can get new thermostatic expansion valves for R134a superheat and the condenser is worthless unless you’re doing an a1 restoration. It’s serpentine style and inefficient for r134a. Red Dot makes much better cross flow condensers that look almost identical to original when you fab brackets for it. The condenser is a critical piece that should be upgraded anyway.
    vince konicki and jeff campbell like this.
  7. Carl Wiese
    Nov 14, 2001
    8,166
    46
    Oregon City, OR
    I kept mine for over a decade, zero interest.
    Sent from my Pixel 2 XL using Tapatalk
    stroker3 likes this.
  8. Sammy
    Sammy Y-Block King
    Oct 22, 2001
    3,043
    402
    Grigsby's Bluff, TX
    Haven't had most of mine that long, some of it is relatively "new" to me but it's all part of the junk that I can't give away that will be headed to the recycler pretty soon. There's always someone wanting it the day after.
  9. Patrick Morris
    5,462
    611
    This is the first thing I though of. My friend did this with his '72 Scout's York compressor. It's a bitchin setup. His front bumper is a 4x4 square tube that the PO welded to the frame. He turned it into an air tank. When he hits the "AC" switch on the dash it pressurizes the bumper. LOL Inflates tires super fast (not counting the time it takes to pressurize the bumper). And he can even run little air tools for short jobs.
    winchested likes this.
  10. stroker3
    Feb 5, 2009
    5,412
    2,424
    Mass.
    In the same boat with things. All you can do is try. Wish I had tossed some stuff years ago. Yes, someone will always need it the day after but there's little value or much appreciation overall for holding onto, storing, moving around and tripping over crap year after year.
