800 Sagging Doors
Discussion in 'General IH Tech' started by Greg704, Jul 12, 2014.
  1. Greg704
    Greg704 Farmall Cub
    Dec 22, 2013
    109
    MARSHVILLE
    I have a 1967 Scout 800. i bought new hinges, put them on.
    first problem.
    The door opening is now 3/4 of an inch to small. i'm hoping i can put a jack in there and open it up. The problem is due the my body work i'm sure.
    Next,
    the door still had a huge sag in it. way low. Is there a way to adjust the hinges??
    Any help please.... Thanks
  2. BuffScout
    BuffScout Farmall Cub
    Jul 25, 2013
    262
    24
    "Forever West" Wyoming
    Before you put your new hinges on, did you replace all body bushings? New bushings will make a big difference if you haven't already replaced them. Did you get the correct ih hinges?
  3. guidolyons
    guidolyons High Wheeler
    Jul 5, 2006
    1,862
    221
    Corpus Christi, TX
    ^^^ How are your body mounts? There are 9 (1 strip under radiator, 2 under driver/passenger floor, 2 mid-body mounts under the bed by the step, and 4 along the back crossmember) The driver & passenger mounts as well as the mid-body mounts tend to sag/collapse/break off the frame.
    Did you mark the doors and jambs before you swapped hinges? There is a small amount of adjustment in the hinges. The hinges bolt to a captured nut plate that "floats" in the door jamb and door. Loosen up the mounting bolts slightly and you can move the hinges around a bit ~1/4". A 1/4" at the hinge can make a big difference at the latch.
