80 Dana 44 front axle spindles
Discussion in 'General IH Tech' started by Ruckus Higginbotham, Apr 23, 2019.
  1. Ruckus Higginbotham
    Ruckus Higginbotham Farmall Cub
    Apr 5, 2019
    Ok folks.... I’ve never done this and found a couple things that help in the search box but how do I proceed pulling these spindles off. Top and bottom are loose. The pic is of my current situation. 1E3D00EA-0F3A-49C9-8A72-CC66C93C7441.jpeg Thanks in advance.
  2. Bussy
    Bussy High Wheeler
    Mar 3, 2011
    2,452
    560
    Gause, TX
    Deadblow hammer. A couple wacks on each side and it should separate from the knuckle.
  3. Ruckus Higginbotham
    Apr 5, 2019
    Hit the spindle with a dead low?
  4. Bussy
    Bussy High Wheeler
    Mar 3, 2011
    2,452
    560
    Gause, TX
    Yep, like orange ones from Harbor Freight, thick plastic coated hammers. The spindle is just stuck to the knuckle if you’ve pulled all 8 nuts off.
  5. Bussy
    Bussy High Wheeler
    Mar 3, 2011
    2,452
    560
    Gause, TX
    Then get a flat head screw driver and separate the two.
    Mark Aycock likes this.
  6. jeff campbell
    15,228
    1,447
    Yup. Smack it down, then up.use a piece of wood against it. It will just barely come loose. Then pry it apart. If it don't come loose after up an down, then go side to side. They're very tight
  7. Dana Strong
    5,535
    1,350
    The first thing that needs to be done is to clean the outside of everything well.
    I use blocks of lead as dead-blow hammers, or a standard heavy hammer pounding on a block of wood against the metal, to keep from damaging parts.
