75 P/U fuel tank selector switch
Discussion in 'General IH Tech' started by ihscoutmatt, Jul 14, 2011.
  1. ihscoutmatt
    ihscoutmatt High Wheeler
    Jun 2, 2002
    1,446
    Donaldson Ar
    anybody know either where to get a new fuel tank selector or of another that will work on a '75 200 mine appears to be messed up it wont change sides and the knob pulls out about 6in
    I have already checked with most of the Light Line and all the local parts houses and the only thing it can find is one from Scoutparts.com and if I remember right it wasn't even a oem type switch
  2. J.J.
    J.J. Dreams of Cub Cadets
    Dec 14, 2003
    4,391
    1,987
    Castalian Springs, TN
    Is it the switch or the unit under the right front fender? It is just a push/pull cable that runs from the dash to the underside. If the cable moves underneath, then maybe the problem is the unit itself. There are many threads that discuss rebuilding them. You could always replace it with a electric unit like I did.
    toggle switch, left position-left tank, right position-right tank (where the choke cable was in the dash)
    view from inside right front fender:
    view from underneath:
    JJ in TN
  3. TBAKPhi22
    TBAKPhi22 Binder Driver
    Sep 25, 2005
    707
    Palo Alto, CA
    I got an electric Pollak selector switch/valve for mine. The old one wouldn't switch tanks either, and when I rebuilt the valve it seemed like it wouldn't completely shut off the tank that wasn't being used.
  4. 1975IH200
    1975IH200 Y-Block King
    3,057
    403
    The original valve is easily rebuildable. Three (3) o-rings and one (1) gasket.
  5. Afireinside2285
    Afireinside2285 High Wheeler
    Nov 2, 2003
    1,705
    21
    colorado
    Ih only north is carrying re-built units but you have to call there not on the website.
    J J What application is the electric unit your using from? Any details on it I like the install it looks like my old chevy truck one. I would like to do that to my 72 1110 travelall.
    thanks
  6. ihscoutmatt
    Jun 2, 2002
    1,446
    Donaldson Ar
    I had done alot of searching before posting cause I was sure it had to have been covered many times before but turned up nothing but deadends :oops:
    thanks for the info on rebuilding:beer:
    I too would like some more info on the electronic one pictured please post up some more info what was it originally for?
  7. J.J.
    Dec 14, 2003
    4,391
    1,987
