727 to T19 tc question
Discussion in 'General IH Tech' started by Arkantex, Mar 26, 2019.
  1. Arkantex
    Arkantex Farmall Cub
    Sep 22, 2012
    70
    Cabot, Ar
    Hey everyone. I am swapping from a 727 to a T19 in my 78 Scout ii. I have the T19 with bull gear, the pedals and linkages. My question is, will the tc off the auto trans bolt up with my t19 with just the bull gear or is there something else needed? I’m trying to make sure I have everything together before I immobilize my scout.
    PS- the T19 came out of a scout ii. Thanks
  2. rdavisabc
    rdavisabc Farmall Cub
    Oct 12, 2010
    254
    82
    Arlington, Tx
    Hey Arkantex, I'm interested in the same thing. What are you doing about the bell housing?
    Rd
  3. Arkantex
    Sep 22, 2012
    70
    Cabot, Ar
    I
    have a t19 bell housing and clutch assembly off a scout ii
  4. tx63conv
    tx63conv Farmall Cub
    Jun 1, 2018
    93
    Dallas, TX
    What are you doing with your auto pedal setup? I am doing the opposite--switching to a 727 and looking for a pedal box
  5. Scoutboy55
    Scoutboy55 Farmall Cub
    Jan 3, 2005
    220
    62
    Monrovia,CA
    TF727 and T18/19 Bull Gears are different. They look very close, but are cut at different angles. Be sure to match the XFR case to the proper one or it'll be a bad day.
  6. Scoutboy55
    Jan 3, 2005
    220
    62
    Monrovia,CA
    Ha! I missed that first sentence completely...You'll be ok. I have done this swap.
  7. WRENCH MAN
    Dec 24, 2004
    4,272
    126
    Eugene Orygun
    NO and yes, it depends on the year, not the transmission, true the auto gear will NOT fit the manual, but the later manual gears are the same pitch as the 727 auto gears.
    read this to see what works with what.
    https://www.novak-adapt.com/knowledge/gear-table/
    click on the chart and it will widen out so you can read it.
    Arkantex likes this.
  8. Arkantex
    Sep 22, 2012
    70
    Cabot, Ar
    Thanks guys. I don't know which year the t19 came out of so I guess I will have to check the angle on the bull gear and compare it to the novak website. Thanks for the link WRENCH MAN
  9. winchested
    winchested High Wheeler
    2,908
    995
    The T-19 I have the bull gear for the Dana 20 was completely different from the bull gear for the Dana 300.
    Sent from my SM-G870W using Tapatalk
  10. Arkantex
    Sep 22, 2012
    70
    Cabot, Ar
    My scout has a dana 20 and the t19 I bought was bolted up to a dana20. Hopefully I will get some free time to play in the shop this weekend an get it all figured out.
  11. Arkantex
    Sep 22, 2012
    70
    Cabot, Ar
    So I pulled the d20 out of my scout and bolted it up to the t19 no problem. I spun the input shaft on the trans and went through 2, 4 high and 4 low. Didn’t feel anything or hear anything abnormal. Is the difference in gear angle minor or so different that they won’t mesh together?
  12. Scott L
    Scott L High Wheeler
    Apr 16, 2003
    1,534
    500
    Collinsville, OK
    From what I’ve seen here, it is minor but will become apparent from the howling coming from under your truck as you are driving. Best to check part numbers to determine compatibility
  13. WRENCH MAN
    Dec 24, 2004
    4,272
    126
    Eugene Orygun
    If you look at the T-19 bull gear it WILL have a "18-8-XX" number stamped in it, look at the chart I linked above and see if the number is one of the 17.5* gears, if it is you're good to go, if not you'll need ti find the right gear.
  14. Arkantex
    Sep 22, 2012
    70
    Cabot, Ar
    Well, the bull gear on the auto that is coming out is a 18 8 56 and the one on the t19 is 18 8 55. According to novak’s Website, they are both 17.5
  15. winchested
    2,908
    995
    That's good then the only difference being the internal splines.
  16. 1975IH200
    1975IH200 Y-Block King
    3,003
    369
    If you wish to type the degrees symbol °, simply hold down the 'option' key and the 'shift key' then hit the number '8' key. °°°°°°°°°°°°°°°°
  17. Packerrailway
    Packerrailway High Wheeler
    Mar 25, 2015
    2,307
    2,024
    Lodi, WI
    Now I admit that I am PPC, BUT, I don't even HAVE an "option key" on my keyboard. Unless that is a different name for some other key?
  18. 1975IH200
    3,003
    369
    Yes, I have a MacBook. °°°
    A Windows based computer uses a different key(s) and a minute of experimenting should determine the combination.
    Packerrailway likes this.
  19. rdavisabc
    Oct 12, 2010
    254
    82
    Arlington, Tx
    Onna Chromebook it's CTRL+SHIFT+U, then 00b0 + ENTER ... all that just to insert a °. Sheesh.
    Rd
  20. 1975IH200
    3,003
    369
    Ouch !! °°°°
