727 High pitched whine in D
Discussion in 'General IH Tech' started by scorp1us, Oct 16, 2014.
  1. scorp1us
    scorp1us High Wheeler
    Jul 28, 2009
    1,495
    Baltimore, MD
  2. jdassler
    jdassler Farmall Cub
    Jul 12, 2012
    179
    Roswell, GA
    Does it change pitch with an increase in RPMs? Sounds more fluid than mechanical from the Youtube video.
  3. Oakland_Jack
    Oakland_Jack Binder Driver
    May 27, 2009
    655
    Alameda, CA
    It is hard to hear, but might be the teeth of the transfer case making slight contact on the front axle coupling. While in D, try slight manipulation of the transfer case shifter and see if there is an effect. If that's not it, turn up the radio louder and enjoy a refreshing PBR.
    -j
  4. FishWagon
    FishWagon Farmall Cub
    Jun 19, 2010
    455
    Dacula, GA
    Sounds like a fluid issue to me.....
    Check your level with engine running and the tranny in neutral (pump does not run while in park so it's important to be in neutral)
    When was last time filter was changed?
  5. JWMorrisey
    JWMorrisey Farmall Cub
    Oct 15, 2014
    7
    Verona KY
    As an old Chrysler tech, we ran into this issue back when these trans were new. The first one encountered, I actually thought it was a vacuum leak.
    The issue back then was that a poor weld job inside the torque converter would allow a few of the vanes to vibrate like a tuning fork in the fluid flow, causing this sound.
    Secure the vehicle properly and get underneath with a mechanic's stethoscope. From what I can see in the video, the truck isn't moving so that eliminates from the planetary gearsets on back. I'm betting the sound is coming from the torque converter or the bushings up in the front of the trans.
    FishWagon is partly correct in checking the trans fluid level in Neutral. The pump is working in neutral but pressure isn't regulated and the torque converter isn't filled in PARK. The fluid level could appear to be 2-3qts overfilled if it's checked on Park.
    SIDEBAR When the outside temps are 0 degrees or colder and the truck has set out overnight, start in Neutral to reduce the risk of blowing out the trans front seal.
