68 Scout 800 in Montana
Discussion in 'Binder Builds' started by MontanaMac, Mar 23, 2015.
  1. MontanaMac
    MontanaMac Farmall Cub
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Hello everyone!
    My name's Scott, and I live in Bozeman, Montana. I've just started to build this 68 800.
    It's got the 266 V8 with the 4-speed. There not much particularly unusual, except that I am very pleased with the minimal rust on the body. It's got the typical rust-through on the floorboards, and just a little along the edges of the rear box, but that's about it!
    My mild build plans for 2015:
    1. Replace both floorboards and cut out rust in the box.
    2. Install roll cage from D&C Extreme.
    3. New seats.
    4. Replace dual tanks with rear-mounted fuel cell.
    5. Rebuild brakes, steering linkage, and make sure everything is safe.
    6. Have fun driving it this summer!
    Post-summer:
    1. Rebuild engine.
    2. Rebuild tranny and axles.
    3. Fabricate new dash panels with fresh gauges.
    4. Body work and fresh paint.
    5. Replace all the weatherstripping, rubber, etc.
    All in all then, a moderate build. The best part though is the journey, and I look forward to learning a ton from you all, and sharing the progress over the next months and years.
  2. eldustino
    eldustino Farmall Cub
    Jul 9, 2013
    45
    Denver, CO
    Great looking truck! Here's to progress over the next few months. This looks like a great starting point! Throw some steel wheels on?
  3. scout2000
    4,362
    1,144
    Very nice truck.
    And welcome aboard. I think you will have a lot of fun with your new truck.
  4. Robert JetFxr
    Robert JetFxr High Wheeler
    May 19, 2003
    1,645
    I am in Billings and there are several good guys that are into 800s in Kalisbel.
  5. MontanaMac
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Well, as I dug into this project, I find that there is a lot more work than originally met the eye! Isn't that usually the case though?
    The rust in the box isn't too bad, just on the bottom corner seam. Unfortunately, the rust also claimed the C-channel box frame members for nearly the entire length. After cutting out that steel, my plan is to weld a length of angle iron on top, and then tie this in to the crossmembers underneath. Ya think that is a reasonable repair?
    I don't think the remaining rust in the box is too bad. Yes, it has pitted the steel, but not close to penetrating. Eventually the entire floor will be covered in Lizard Skin. What primer or other product is best to stop this rust from progressing further?
    The floorboard rust was a bit worse than I thought. It's not just the flat bottoms, but also into the sides, especially along the transmission hump. I removed the entire interior and much of the front clip to make it easier to cut out all the rust and replace it with fresh metal.
    Any comments and suggestions are very welcome!
  6. Scouter66
    Scouter66 Farmall Cub
    Aug 31, 2012
    Whitefish, MT
    Congrats on the Scout!
    I am one of the guys from Kalispell Jetfxer mentioned.
    I think the repair to the bed will be very nice and stout. Your bed is enviable! Mine was way worse as far as overall shape goes. It had factory installed bed and floor board liner that kept the moisture right there on the metal and rusted away for years!
    I replaced all the floor boards in my 800 from the bend that goes to the firewall back to the front of the bed. just remember not to move it around to much and keep it braced when cutting things loose so you don't get any flexing.
    I work with a product called Master Series Coatings Silver. It is an excellent industrial coating that has made the move into the auto resto market. Incredible stuff. Let me know if you need some. It truly is the best I've used.
    I sent you a personal message as well about our upcoming show and shine.
    Let me know how I can help you!
  7. MontanaMac
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Thanks Scouter66. I did go ahead and weld some 2x2 angle iron in the bed. I was a little afraid of welding two different thicknesses of metal either not heating the angle enough or burning through the sheet metal, but it worked out okay. I'm by no means a welder, but I skip welded this together which is not pretty, but I think it will hold up well.
    The photos are before grinding, so they are presented here in all their ugliness!
    The angle iron did work well, and I tied it in underneath to the bed crossmembers.
  8. Boaty
    Boaty Farmall Cub
    Jul 23, 2014
    294
    Hendersonville, NC
    Cool Scout! I always get a little envious of guys that do not have a lot of rust in their Scouts. Oh well...
    Boaty
  9. MontanaMac
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Finally got some time to work it some more. Removed front and rear axles in to prep for body and frame work. Started some body work on the rear...
    I realize I am lucky to have just a little rust, but I want to repair all the cancer. Here's the left rear:
    Repaired similar rust with a bit of an added dent on the right rear:
    I apologize in advance to the purists who who really like the side gas fillers. I don't, so I decided to cover them up:
    That's about it for now. Gonna undercoat the rear and get to work on the axles as soon as all the welding and body work is done on the back half.
    gwinter1129 likes this.
  10. ddedman
    ddedman Farmall Cub
    Aug 27, 2008
    441
    Kalispell, MT
    That looks fairly pristine and I like the color.. like Scouter I am also from kalispell. Don't no much about the 800 however. Here to help if I can .
  11. 64desertscout
    64desertscout Farmall Cub
    May 9, 2013
    476
    68
    Menifee, CA
    Nice 800, I've always wanted an 800.
  12. Bussy
    Bussy High Wheeler
    Mar 3, 2011
    2,452
    558
    Gause, TX
    Not sure how you posted these pics to show progress but that was cool to watch. Please share.
  13. gwinter1129
    gwinter1129 High Wheeler
    Dec 22, 2011
    1,318
    264
    Monroe Twp, NJ
    Montana Mac, great pics and so is your welding, Greg
  14. scout2000
    4,362
    1,144
    Hello Tracy,
    It looks like just a standard animated gif file.
  15. customtronic
    customtronic Farmall Cub
    Nov 15, 2011
    454
    64
    Olympia, WA
    Great looking Scout!!! I wish my 800b Comanche was in that good of shape! I'll be following along on this build for sure. Thanks for posting.
  16. MontanaMac
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Yes, as Jerry said a couple posts up, it is just a animated GIF. I did that mostly to show progress without having to take up a lot of space.
    There are a lot of free online tools you can use to easily make these. I used ezgif.com
    customtronic likes this.
  17. MontanaMac
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Last year I proclaimed that I had "mild" build plans for this Scout. Apparently I lied. But while restoring the rear brakes, I pulled the axles and found rust inside, which led to a rear-end rebuild. With the rear axle out, it made access to the rusty rear quarters easy, so why not fix that? It would be silly to rebuild the rear end without doing the same to the front end, right? Okay, with those jobs done, I could now concentrate on replacing the rusty floorboards. But wait, it would be so much easier to get all around the floors and tunnel if the engine and rest of the drivetrain were out of the way! Well, shoot, now that the engine is out, it's not much more work to just remove the frame. Now that the frame is off, I can completely restore the body, sand and paint the frame! Whew there is literally no end to the fun this wonderful machine provides! So much for the mild build....
    Wombat and Top Ramen like this.
  18. MontanaMac
    Mar 22, 2015
    93
    62
    Bozeman, MT
    Cleaned up and painted the frame. Used Rust Bullet on the bare frame, top-coated with flat-black from a rattle can.
    CoopVA likes this.
  19. Alex
    Alex Farmall Cub
    401
    33
    On The, Edge
    I'm not sure I've ever seen project creep so clearly described in words and pictures.
    Now for the mechanicals - after all, with the engine / trans / TC out .....
  20. supermerle
    supermerle Binder Driver
    Dec 29, 2009
    701
    33
    Atkins, AR
    Yep, Ain't the sickness great when you buy a scout. ;)
