63 scout 80 152ci timing proceedure
Discussion in 'General IH Tech' started by Klblackb, Nov 6, 2018.
  1. Klblackb
    Klblackb Farmall Cub
    Aug 1, 2018
    I am trying to set timing on my scout. My question is do you set the timing with the vacuum advance connected or disconnected? I’m getting about 15 degree difference between the two. I set it a 5 btdc with disconnected and when I looked at it after hooking back up it was at about 20 btdc. Seems excessive to me? These were done at idle speed. I’m sure someone out there can answer this question. Any help appreciated. Thanks. Keith
  2. jeff campbell
    15,228
    1,447
    Yes.unhooked and vacuum line plugged !
  3. 1975IH200
    1975IH200 Y-Block King
    3,151
    469
    What exactly is your idle speed?
  4. Klblackb
    Aug 1, 2018
    Not sure exactly, but would guess maybe 600 rpm.? What should it be? Thanks
  5. 1975IH200
    3,151
    469
    600 rpm is good, but if you don't know what rpm the engine is running, then you don't know if the centrifugal advance is engaged or not.
    Guessing isn't knowing.
