6 hole to 5 hole fuel tank sending unit adapter
Discussion in 'General IH Tech' started by Bobcat, Sep 10, 2013.
  1. Bobcat
    Bobcat Farmall Cub
    Apr 12, 2012
    Clovis, nm
    I just swapped out my gauges and of course my fuel tank sending units are different. I knew that going in to this. However, poking around on speedway motors I came across this 6 hole sending unit to five hole sending unit adapter. It is for 1935 - 56 ford car or pickups. I was wondering if this would work for the scout 800 side tanks.
    Specs:
    Adapter plate is 3-1/4" O.D.
    Center hole is 2-3/4" I.D.
    5-hole mounting pattern for new style sending unit has one spacing at 1.38" and the remaining four at 1.25"
    6-hole spacing going clockwise is 1-9/16", 1-3/16", 1-7/16", 1-3/16", 1-7/16", 1-5/16" for the stock type pattern
    Comes with six screws and gasket for the adapter and five screws for the new sending unit
    here is the link from speedway:
    http://www.speedwaymotors.com/1935-1956-Ford-Fuel-Sender-Adapter,5865.html
  2. guidolyons
    guidolyons High Wheeler
    Jul 5, 2006
    1,768
    132
    Corpus Christi, TX
    Dunno..but you can disassemble the sender and use your old mounting plate with the new guts on it.
