4.3l tbi temp sensor question
Discussion in 'Injection Tech' started by Anthony1982, Apr 8, 2019.
  1. Anthony1982
    Anthony1982 Farmall Cub
    Feb 27, 2013
    47
    Orlando, florida
    Anyone know of a compatible gm temp sensor with a 1/4 inch size fitting instead?
  2. c5wagner
    c5wagner Farmall Cub
    May 7, 2015
    30
    Highland, CA
    Why would you bother? If this is for the Jeep 4.0l head, just get the later jeep 4.0l thermostat housing and put the gm temp sensor in that sensor hole like the later jeep 4.0l efi uses. It is the right size and worked great for me and my TBI setup.
  3. c5wagner
    May 7, 2015
    30
    Highland, CA
    It will also read the correct temp as the heater hose passage isn't controlled by the thermostat if that is what you are worried about. [​IMG]
  4. Anthony1982
    Feb 27, 2013
    47
    Orlando, florida
    I did do that and the sensor didnt fit
  5. c5wagner
    May 7, 2015
    30
    Highland, CA
    Weird, maybe the one you ordered was for an even later jeep. I got one from autozone for a 91 jeep wrangler and it worked great.....
  6. Bill USN-1
    16,962
    204
    Can't you just use a 3/8 NPT tap to make the hole the correct threads?
  7. Anthony1982
    Feb 27, 2013
    47
    Orlando, florida
    You are right. I ordered another one and got the right housing thanks. Now I'm working on the power steering pump because I'm using a 4.0 head with the horseshoe manifold with a tbi setup on a 4.2 block
    c5wagner likes this.
  8. Anthony1982
    Feb 27, 2013
    47
    Orlando, florida
    I could I guess. But I found out I ordered the wrong part. BTW thnx for the tbi adaptor plate for my horshoe manifold. Solid!!!
  9. c5wagner
    May 7, 2015
    30
    Highland, CA
    I can't remember what I did. I'm pretty sure I brought out the welder and made it work by making the bracket different but that was back in 2015 so a little past my memory for details.....
