345 heads on an IC392?
Discussion in 'The Skunkwerks' started by Zorak, Jul 26, 2020.
  1. Zorak
    Zorak Farmall Cub
    Jul 22, 2020
    hey, first post so here i go...
    i have a 1978 Scout2 with a 345A, i am looking to build a 392 short motor and fit my existing 345 heads, Isky cam and RPT alloy inlet.
    my question is as the IC 392 is fairly available, can that block be easily modified to suit the non IC 345 heads, or the heads be modified to suit the IC block?
    thanks
  2. Jeff Jamison
    7,632
    1,071
    Cant be made to work,the cooling passages are different,it would work with an older 392
  3. jeff campbell
    15,456
    1,555
    Yup.non improved cooling 392
  4. walkersscout
    walkersscout High Wheeler
    Oct 5, 2005
    1,588
    265
    AZ
    Yes it works with non IC. There is no advantage though. You get a smaller combustion chamber for higher compretion, but you lose the bigger valves. You will hear lots of mumbo jumbo about improved bottom end or more torque, but from experience it felt like a little bit of a loss. The one thing you do lose that is benificial is the propensity of the 392 heads cracking.
  5. 1975IH200
    1975IH200 Y-Block King
    3,251
    532
    If you want to increase the compression ratio of an IH SV-8 engine:
    a) Zero deck the block.
    b) Mill the heads.
    c) Instal the correct pistons.
    It's that simple.
  6. Zorak
    Zorak Farmall Cub
    Jul 22, 2020
    thanks for the replies.
    there are a few reasons for wanting to keep the 345 heads, main reason is i already have modified the ones i have, another is the engine wont see high rpms so the smaller valves wont be a problem. although thinner stems would be desirable, also I had read the 392 heads have a different valve angle than the 345, but i don't know if this is correct.
    i have been offered a 392 that was a warranty recall due to overheating issues, the engine was completely stripped and put into boxes about 35 years ago. i haven't seen the engine so i can not confirm if it's an IC version or not. Was the IC 392 released in the 1970's or 1980's?
  7. Zorak
    Zorak Farmall Cub
    Jul 22, 2020
    i know this is the difference and wondered if anyone had welded and moved the location of the cooling galleries to suit
  8. tdc
    tdc Dreams of Cub Cadets
    Sep 8, 2005
    4,211
    2,241
    PNW
    This one is a 1973 392 improved cooling. It will power a Scout ll soon.
    392ic 7.4.2020.jpe
  9. Zorak
    Zorak Farmall Cub
    Jul 22, 2020
    are you installing the engine as is, or planning to do some work to it first?
