32 in tires
Discussion in 'SSII' started by Jacob, May 9, 2017.
  1. Jacob
    Jacob Farmall Cub
    Sep 9, 2016
    Holden, MO
    When I bought new tires, I bought the same size as the p.o. put on in 87. Should a stock ride height ss clear 32s? Or am I working with an old lift that I don't know what is? This is the sidewinder from an earlier post, the wife got me talked into painting it
  2. bull
    bull Binder Driver
    Aug 14, 2010
    925
    155
    some where in the ether
    32's should easily fit on a stock ss2...im not really seeing what your problem is though...31's are more than adequate
  3. Jacob
    Jacob Farmall Cub
    Sep 9, 2016
    Holden, MO
    Forgot to mention that I getting ready to do some suspension work. I thought it may be lifted if it cleared 32 with 40 years of spring sag. So new stock size springs should work?
    milfrog1 likes this.
  4. BinderBookie
    BinderBookie High Wheeler
    Apr 25, 2014
    2,384
    997
    A Farm in Ohio
    There are a few things you can do to make it less a Wild-Assed Guess (WAG) and lessen the changes of being forced to make a "wing-and-a-prayer" fit.
    There are "32s" and there are "32s". How a tire fits is very dependent on the rim used. Each tire has a range of specified rim widths. The section width (the width of the sidewalls not the tread) will increase at the wider end of the rim width spec and decrease at the narrow end. Also, the backspacing of the rim will effect how the tire interferes (or doesn't) with the wheel wells and suspension. Bottom line, if it clears now, it will clear with a lift, or with non-sagged springs. If you haven't test fitted them yet, it's a crapshoot unless you know all the parameters. On top of all this, each brand tire is slightly different in what it defines as a "32" (or whatever size).
    If I were you, I'd ask for some guys with fresh stock springs to measure the distance between the top of the axle and the bump stop, or other fixed points mutually agreed upon, and compare that to yours. If yours is currently the same or lower, the tires should fit. If not, there may be issues. Also, compare the mounted dimensions from the tire spec sheet between the tires you have and the tires you want (I am assuming you will swap them over to the rims you have now). One company's "32" may be 31.4" tall and the other is actually 32 inches. Plus, the section width may be different. Factor in a spec called "measuring rim width," which is the rim width used to obtain the published diameter and section width measurements. If your rims match the measuring rim width, that is another good predictor of finding a tire that fits.
  5. Darrel
    4,217
    779
    It looks stock. 9.2" to the bottom of the frame as delivered.
    John Felkins likes this.
  6. BinderBookie
    Apr 25, 2014
    2,384
    997
    A Farm in Ohio
    But with what size tires? That is the variable in the equation that you can't guess at. A half inch off could be "fit-or-hits."
  7. Darrel
    4,217
    779
    H78-15
  8. BinderBookie
    Apr 25, 2014
    2,384
    997
    A Farm in Ohio
    In my vintage tire books I can have here and there are four different mounted diameters in the "H78-15" category and three different section widths. H78-15 might be close enough but a half inch either way with either direction could mean the tire hits. Measuring between the top of the axle and a fixed place on the chassis show a dimension that is not dependent upon tire diameter. If his is NOT hitting at or below the dimension on a stock rig, his tire upgrade should work with stock springs. Assuming the rig with stock springs is at a similar weight.
  9. Darrel
    4,217
    779
    Jacob,
    You could post up some pictures, but it doesn't appear you have lift springs. If you're just running around town and graded roads 32's will be ok stock height. I would expect some rubbing if you offroad. Do you still have the original body bushings?
  10. Jacob
    Jacob Farmall Cub
    Sep 9, 2016
    Holden, MO
    I've not replace the body bushing. Here are some pictures from the under side 20170518_201407.jpg 20170518_201430.jpg
  11. winchested
    3,058
    1,085
    Those are bumpstops. Looks like your S2 has very flat springs like mine.
  12. Jacob
    Jacob Farmall Cub
    Sep 9, 2016
    Holden, MO
    I figured that the bump stops would provide the visual for the shape of the spring
  13. BinderBookie
    Apr 25, 2014
    2,384
    997
    A Farm in Ohio
    Yeah, they look pretty sagged to me as well. Not much travel left.
  14. Darrel
    4,217
    779
    So you do have stock springs. New springs will give you more tire clearance as will replacing the body bushings. What you could do is replace the springs first and see how you like the height. You would still have the option of adding stock or 1 inch lift body bushings, and longer shackles for more clearance. If you're going to take it off road however I would get the Skyjacker 2" lift springs. Many people have posted pics of their Scouts with those springs over the years if you want to see how they look. Patrick Morris has them.
  15. bull
    bull Binder Driver
    Aug 14, 2010
    925
    155
    I would just have those stock springs rearched.....you will never be able to get that spring steel quality today...
  16. Darrel
    4,217
    779
    Re-arching never lasts.
  17. bull
    bull Binder Driver
    Aug 14, 2010
    925
    155
    Oh really..since when
  18. winchested
    3,058
    1,085
    Read up on cold arching vs hot arching. Cold arching is said to not last long.
  19. Jeff Jamison
    7,316
    913
    even my local spring shop states reaching doesn't last,they recommend replacing atleast the second leaf when reaching as that helps them last.
  20. Jacob
    Jacob Farmall Cub
    Sep 9, 2016
    Holden, MO
    Does anyone have any experience with the 2.5 in rough country lift? They look cheaper than getting stock springs and the scout is on a money diet
