3 speed, 4 speed questions.
Discussion in 'Diesel Tech' started by OldGu, Aug 16, 2019.
  1. OldGu
    OldGu Farmall Cub
    Jun 13, 2019
    Greetings. The old Nissan is running! Thanks for all the help. So my 74 Scout 11 has a Nissan with a 3 speed. It's 2 wheel drive. If I wanted to drop in a 4 speed, what fits? Would it have to be a 2 wd tranny, or does a 4 wd fit? Still new at this. Any difference between gas or diesel tranny?
  2. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    199
    Sunland, Lompoc, CA
    Glad you got it running.
    The transmission "bell housing" is Diesel only. If you take a look at where it bolts up you'll see that the interface is round. It's an SAE #4 (I think) pattern. The part it bolts to is mounted to the engine behind the flywheel and stays with the engine.
    I had a housing once, don't recall if it was for a three or four speed but it was like ten inches long. I dunno if the transmissions were unique to the Diesels.
    Maybe search here and in the classifieds for a picher.
  3. blue smoke
    blue smoke High Wheeler
    Sep 28, 2008
    1,263
    57
    Melissa Texas
    If the Nissan was in a Scout originally any scout transmission will fit except the automatic. The scout used a Borg Warner T 19 close ratio in the diesel Scout.
    The scout used a married transfer case. So you want to look for one that was 2 wheel drive. Or from a IH full-size which can be either 2 or 4 wheel drive since the full size used a divorced transfer case. If it is a full size it could be a t-18 which means no syco first gear
  4. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    199
    Sunland, Lompoc, CA
    But he needs the Diesel bell housing, no?
  5. Dana Strong
    4,734
    917
    If he already has a Diesel engine with an IH transmission mounted to it, and if both the 3- and 4-speed units all use the same mounting, then he just needs an IH 4-speed transmission which has a driveshaft output. He must already have the correct bell housing.
  6. Joe S
    Joe S Farmall Cub
    Oct 27, 2011
    199
    Sunland, Lompoc, CA
    Oops. Reading comprehension fail. I thought he had an auto.
  7. Dana Strong
    4,734
    917
    Well, he only said "Scout 11 has a Nissan with a 3 speed" so theoretically, it could have been a three-speed auto...
  8. jeff campbell
    14,114
    933
    Or they're thinking a 4speed with granny low is 3 speed ? Possibility ??
  9. OldGu
    OldGu Farmall Cub
    Jun 13, 2019
    I need to be more specific. I have a 3 speed manual behind my Nissan. Wondering what 4 speed would fit.
  10. jeff campbell
    14,114
    933
    T-19 will.I have 1 if needed.
