3 Point (Shoulder) Seat Belts - D Series Travelall?
Discussion in 'General IH Tech' started by MrKenmore, Jul 29, 2019.
  1. MrKenmore
    MrKenmore High Wheeler
    2,815
    745
    I'm looking at the threaded insert in the B pillar. Looks like IH was preparing themselves for required shoulder belts. It's listed in the brochure as "shoulder harness anchors". I would very much like to make use of this. Has anyone on BP done this before? It appears 73-87 GM trucks would be a close match. The aftermarket is pretty decent. Although it is not an exact match for the GM style, I think it'll get the job done.
    From LMC: http://www.lmctruck.com/Features/CC/CCCG8.htm
    From Seat Belts Plus: https://www.seatbeltsplus.com/product/CHT7387-BEN.html
    (These look like a better match)
  2. Gringo Gomez
    Gringo Gomez Farmall Cub
    May 7, 2015
    109
    39
    Lawrenceville, NJ
    I used that anchor point in my '68.
    No problem.
  3. MrKenmore
    2,815
    745
    Do you remember what seat belts you used?
  4. mallen
    mallen High Wheeler
    2,579
    441
    I would go with seat belts plus. Or more accurately, I PLAN on going with seat belts plus. They will send you swatches of the seat belt material in various colors so you can choose the right color, and their prices seem very reasonable. (The D series trucks also have the anchor points. I understand that it was a federal requirement after a certain model year, but before the seat belts themselves were mandated.
  5. MrKenmore
    2,815
    745
    Now that is interesting!
  6. jeff campbell
    14,400
    1,043
    Them engineers were smart ! Thinking ahead of their time.
  7. mallen
    mallen High Wheeler
    2,579
    441
    In some forums I have seen arguments about whether or not retrofiting 3pt harnesses is a good idea. Obviously if the mount points were put there by the engineers that designed the vehicle, it should not be a problem. However there were arguments about whether you could retrofit them to vehicles that were older and had no provision for them. There were the typical wide eyed "safety arguments" about how "I wouldn't be comfortable doing that" and "your life inst worth the risk" and there were more reasoned arguments about potentially causing unforeseen problems (if you knew what they were yet wold not be unforeseen,right?) A good analogy is that adding air bags to an old vehicle would be a very bad idea. There is just to much engineering in exactly where to place them and how much energy to deploy them with. (A friend of mine worked on some of that early research and told stories about some of the initial propellants that they tried,that took the heads off the crash test dummies! Hilarious, unless your the crash test dummy) What convinced me that the 3pt harness debate was settled, in favor of adding them to any vehicle, was the insurance companies. Insurance companies such as Haggarty, recommend 3pt harnesses. They have the data, and if it was a problem, they would not tell you to do it. Not only do they have access to all the data to know that they work properly, they are the ones to have to pay out if you get injured, and if it made things worse, they would get sued and pay even more because they TOLD you to install it. (And there is nothing an insurance company hates more than paying out money)
    Of course,on the D line vehicles, its moot, as they are provisioned with mounting points from the factory. Speaking as someone who rolled a truck (with only lap belts to protect me), everyone should put three point harness into their D lines.
    https://www.hagerty.com/articles-videos/articles/2005/09/01/seat-belts-and-your-collector-car
    oneof3k and MrKenmore like this.
  8. YankeeWhite
    YankeeWhite Farmall Cub
    Aug 6, 2003
    202
    Kansas
    I bought a kit for my 74 and they worked great once I figured out the hardware combo at the bottom.
  9. MrKenmore
    2,815
    745
    Did you get it from seat belts plus? I am trying to figure out how things go with that bracket on the non retractable (fixed) end. I know the stock GM units has a pin and retractor activator that protrudes into the B pillar.
    This is the Seat Belts Plus GM 73-87
    Chevy K5 Blazer style
  10. Gringo Gomez
    May 7, 2015
    109
    39
    Lawrenceville, NJ
  11. MrKenmore
    2,815
    745
    Nice! Very simple.
  12. dan1500
    dan1500 Binder Driver
    Apr 12, 2003
    593
    53
    Fort Wayne, IN
    One thing to keep in mind is the anchors in my opinion are a little on the low side in the vehicle. Some of the belts will have an extension between the hanger and where they mount. You definitely want ones where the mounting bolt is right at the hanger without any extension
  13. Gringo Gomez
    May 7, 2015
    109
    39
    Lawrenceville, NJ
    The OEM lap belts (non- retractable) that came in the Rhino had the same GM style buckles that you're lookin' at.
    But I chose cheap...and simple.
  14. ihv800
    ihv800 Farmall Cub
    Aug 20, 2004
    128
    27
    CO
    I have a '73 1210 that was ordered by the Forest Service. It has what I believe were factory shoulder belts in it. It was another belt and buckle in addition to the lap belt. There are also storage clips to keep them out of the way behind the doors when not in use (even spring clips to retain the tail). Never seen another set like it.
  15. MrKenmore
    2,815
    745
  16. MrKenmore
    2,815
    745
    So when I got the Travelall, the retractors were mounted at the shoulder attachment point. No lap belt.
    Here's the lower mount
    Switched things around for now
    Bolt and threaded insert is 7/16-20 fine thread. I ordered a tap to chase out the insert to clean things up.
  17. sabercat
    sabercat Farmall Cub
    Jul 12, 2016
    130
    33
    Kentville Nova Scotia
    back in the early 1970 s GM had separate lap belts and shoulder belts (the shoulder belts were non retractable and when not in use the slid into a bracket above the door)there were two buckles in the seat to connect to one for shoulder the other for the lap belt
    i had this set up in two full sized cars 1971 buick lesaber and 1972 pontiac parisienne
  18. Gringo Gomez
    May 7, 2015
    109
    39
    Lawrenceville, NJ
    7/16 NF - the new belts should come packed with the same.
    That stock retracter may not work properly inverted.
  19. Patrick Morris
    5,270
    531
    Interesting thread. I've had SBP 3-pt belts in my Scout for over 10 years now. Work fine. The top piece attaches to a tab I welded to the outboard edge of my roll bar. I just went with their basic black webbing and their "Euro" style buckle setup because I have bucket seats. I actually just drove over to their shop an bought them one day. They're in Oceanside, which is only 30 miles from my house.
    For anyone who has buckets, surplus HUMVEE belts are another option. I've seen them for sale without the additional and unnecessary hardware for less money than this. (just too lazy to look them up):
    https://www.ebay.com/itm/HMMWV-HUMV...EAT-BELT-KIT-4X4-OFF-ROAD-TRUCK-/222354760756
  20. roguemustang
    roguemustang Farmall Cub
    Nov 10, 2017
    65
    I haven't gotten my truck running to worry about seat belts yet, but in my '56 Ford Customline I installed 3 points for the driver and passenger. I bought them from Juliano's and got the mounting points as well. I wasn't comfortable installing them myself, so I had my father in law (former welder by trade) weld in the shoulder anchors. Thankfully I haven't put them to the test, but I've always felt better knowing that I have them. I've never understood why you see all the expensive customs in the magazines with just a lap belt...if you put that much money into it, why not make it safer as well?
