2wd Scout wheel bolt pattern
Discussion in 'General IH Tech' started by harvey, Oct 11, 2014.
  1. harvey
    harvey Farmall Cub
    Apr 7, 2003
    72
    Keokuk Iowa
    Does anyone know the wheel bolt pattern of a 2wd Scout? and would the 80/800 pattern be the same as the Scout 2? Thanks.
  2. Eric VanBuren
    May 7, 2004
    6,011
    26
    Maple Valley , Wa
    The SII bolt pattern is 5 x 5.5" for 2wd and 4wd since they use all the same components except they have a straight tube w/o a pumpkin in the center. On the early S80 I believe they use a 4 lug pattern and unfortunately I don't know what pattern that is but I would bet it is 4 x 4.5" as that was a common 4 bolt pattern back in that time period. I think at some point they switched the 2wd early Scout to the 5 x 4.5" as used on the 1/2 ton 2wd full size for a while.
  3. tdc
    tdc Dreams of Cub Cadets
    Sep 8, 2005
    4,220
    2,243
    PNW
    5 on 5.5" with a 4.25" center bore.
  4. Carl Wiese
    Nov 14, 2001
    8,171
    52
    Oregon City, OR
    There were 2wd Scout 80's with 4 lug axles. I don't remember the pattern, but I've seen one and Scoutparts had some brake drums for them for stupid expensive.
  5. George Womack
    George Womack Y-Block King
    Oct 13, 2001
    3,241
    278
    Terlingua, TX
    The 4 bolt Scout 80 pattern is 4 on 4.5".
  6. harvey
    harvey Farmall Cub
    Apr 7, 2003
    72
    Keokuk Iowa
    I have seen an 800 2wd and a Scout 2 2wd that both had a smaller pattern than the
    5x 5 1/2 that all the others have. I think the 800 had Ford Ranger wheels on it, but not sure. So did some of them have a different pattern or were the ones i seen modified?
  7. Eric VanBuren
    May 7, 2004
    6,011
    26
    Maple Valley , Wa
    Like I said the early 80 had the 4 x 4.5" the same as the Falcon/early Mustang 6cyl. The 800 at least in some years had the 5 x 4.5" which is the same as the early Mustang V8, today's Mustang, Ranger, Crown Victoria and the midsize Fords from the 70's as well as midsize Chryslers and AMC cars. The SII had the same 5 x 5.5" as the 4wd.
  8. Soopernaut
    Soopernaut Farmall Cub
    May 1, 2012
    175
    Des Moines, IA
    I concur.
  9. harvey
    harvey Farmall Cub
    Apr 7, 2003
    72
    Keokuk Iowa
    So what about the Scout 2 I saw that had the smaller bolt pattern? Were any of them a smaller size from the factory? And the axles were not from an 800 or 80 model and the front axle was 2wd and had disc brakes on it.
  10. pscrambler
    pscrambler Binder Driver
    Jan 7, 2010
    566
    12
    Osawatomie, Ks
    I have had a 74 2wd with disc up front and the bolt pattern was the same as my 79 scout ii 4x4....
  11. Jeff Jamison
    7,885
    1,215
    I have a 73 2 wheel drive with drum brakes,same bolt pattern at all scout IIs,5 on 5 1/2
    TorqueMonster1 likes this.
  12. Germain Fenger
    Germain Fenger Farmall Cub
    Apr 12, 2020
    Do the 60 falcon 4 lug drums fit the scout 80? Found them for much less then scoutparts.
  13. scoutboy74
    6,729
    1,165
    You can find almost anything for less than that vendor wants.
  14. Germain Fenger
    Apr 12, 2020
    Confirmed that the ford wheel drums for falcon do not work for scout 80 with 9" drums.
  15. Howard Pletcher
    Howard Pletcher Farmall Cub
    Jul 23, 2007
    305
    122
    Fort Wayne, IN
    Whatever it was, it didn't come from the factory that way.
