266 torque convertor question
Discussion in 'General IH Tech' started by michigan scout, Jun 21, 2019.
  1. michigan scout
    michigan scout High Wheeler
    Feb 16, 2007
    1,044
    Shaftsburg, Michigan
    is there a difference in a 727 torque convertor from a 304, 392, 345??? Asking because just curious if I can use one of those on a 266?
    I am in search of a flexplate for a 266 including spacer etc. to put a 727 on it
  2. scoutboy74
    6,355
    918
    The closest you can get all the way around is for 304. The 266 was discontinued around 1967-68 and IH didn't use the 727 until late '71 to early '72. So the two were never mated together from the factory. The engines are externally balanced and the flex-plate is part of that balance, so there is a chance you could have vibration issues, but flex-plates have gotten swapped around quite a bit by folks and it generally seems to work alright. For the converters, different engines likely had different stall speeds in the converters. Like I say, when you order up your new converter, just go with specs from a 304 powered Scout II because that is as close as you can get.
    BinderBookie and jeff campbell like this.
