1980's Jeep wagoneer Axles Scout 800 Swap
Discussion in 'General IH Tech' started by Rembrant88, Sep 4, 2013.
  1. Rembrant88
    Rembrant88 Farmall Cub
    Aug 16, 2013
    46
    Boise, ID
    I did some searching but couldn't find much on the subject. If someone were to provide a link to a build than that will help. Could be I missed something in the search.
    So I might pick up my buddies 1966 scout 800. I thought it was an 80 but turns out it's the same year as mine. I was considering going with his 6.2 diesel swap idea but if I get it I'm most likely going to go with a ford 302 and e4od transmission. I bought a 93' bronco to swap the guts to from my wrecked 86' bronco with a 6.9 idi. So I'm going to have a 302 with 147,000 miles on it as well as a good transmission lying around. Now of coarse that leaves me with a drivers side drop problem. So my idea is to pull a drivers drop dana 44 out of an early 80's wagoneer and naturally the rear as well. I'm aware of what is involved with a scout 2 dana 44 swap but not jeep 44's. Anybody know what difficulties are involved here? Any special problems with the swap? Thanks.
    I'm sorry if ford and jeep stuff in a scout bothers anybody. I'm just trying to save the scout from possibly being crushed, so I think it is a good alternative :sweatdrop:.
  2. az scout guy
    az scout guy Binder Driver
    May 31, 2009
    656
    Apache Junction,AZ
    The waggy rear is soa and the front is sua, spring hangers/ perches need changed. If you can think and weld it ain't that hard. The waggy width is nice under an 800\80 and flat tops with Chevy brakes
  3. Rembrant88
    Aug 16, 2013
    46
    Boise, ID
    Thanks for the reply. Luckily I can think, and weld. I've never tried both at the same time though, could be messy...
    I know that on the scout 2 dana 44 front end the passenger side perch is a machined part of the gear housing. Is it the same on the wagoneer? If so than I might just do the same ford coil spring front suspension I'm doing on my other scout by buying the bronco wedges and forget messing with that perch. I seem to have a lot of ford parts around for that kind of thing.
  4. ruderunner
    ruderunner High Wheeler
    Mar 13, 2004
    2,119
    Hiram, Ohio
    Pretty sure the Waggy axle has the perch as part of the casting, I know the pass drop versions do.
    Off hand I can't remember the spring spacving on a Waggy but IIRC it's pretty close.
  5. carnuck
    carnuck Farmall Cub
    Aug 27, 2005
    172
    seattle, wa
    There is a kit that's bolt on to make the FSJ axles SOA. I think it's TTFabworks
  6. ruderunner
    Mar 13, 2004
    2,119
    Hiram, Ohio
    With the E4OD trans and it's Borg Warner t case, you rear driveshaft will be about 16inches long. I wouldn't consider a SOA practical with that short a shaft.
  7. Rembrant88
    Aug 16, 2013
    46
    Boise, ID
    My plan is to use a ford np205 that I have in the garage. I can't remember how much shorter it is than the BG t case, 7" maybe? But it should be enough to make up for the extra length of the e4od wouldn't you think? I can always keep the front spring under and make the rear spring under. I don't care either way because my tire size will be 30's and it's not going to be doing anything serious off road.
  8. ruderunner
    Mar 13, 2004
    2,119
    Hiram, Ohio
    Pretty sure the 205 will gain some length on the shaft. But if you don't plan a lift even the short shaft should be ok. It's the angles of the u joints that get to be a problem and the angles grow faster with a shorter shaft per any amount of lift.
    I don't see anything wrong with either case as long as you keep em full of oil.
  9. Rembrant88
    Aug 16, 2013
    46
    Boise, ID
  10. Scavenger Scout
    Scavenger Scout Binder Driver
    May 25, 2013
    558
    Central, IA
    205 cases are clockable and there's no need to stay driver's side drop
  11. ruderunner
    Mar 13, 2004
    2,119
    Hiram, Ohio
    Clockable yes but not flipable. Whichever side the output is on is the side it stays on though you can tweak the overall height.
  12. Rembrant88
    Aug 16, 2013
    46
    Boise, ID
    I hope I don't need to clock it if I go with the 205, but it's good to know I can. I'm thinking the 208 might have a problem hitting the frame. I guess I'll find out. One thing I like about going with the 208 is the lower gear and ease of setting up shift linkage. And not having to build a support, that's nice too.
  13. carnuck
    carnuck Farmall Cub
    Aug 27, 2005
    172
    seattle, wa
    208 is considerably smaller than 205. Dodge or Chev (pre '88) 205 should be RH drop.
  14. ruderunner
    Mar 13, 2004
    2,119
    Hiram, Ohio
    My 65 80 has a 318/NP435/NP203 combo in it. The tcase is tight to the frame but the 203 is a huge case. 208 should fit fne.
