1978 scout terra or traveler?
Discussion in 'General IH Tech' started by Bigbt3, Apr 14, 2018.
  1. Bigbt3
    Bigbt3 Farmall Cub
    Jan 8, 2014
    Yorktown
  2. stroker3
    stroker3 Y-Block King
    Feb 5, 2009
    3,660
    1,113
    Mass.
    If the thread title is the question, as it sits now with what I think is a back seat and no bulkhead . A traveler. Even with the steel tailgate.
    They're not that hard to swap so it could have been a Terra at one time and someone pulled the bulkhead and added the seat.
  3. Bigbt3
    Bigbt3 Farmall Cub
    Jan 8, 2014
    Yorktown
    Yes, it was a question. I ran VIN # and it comes up as a pickup. I was thinking terra that has been converted. Thank you!
  4. MrKenmore
    MrKenmore High Wheeler
    1,577
    216
    Terra came with the drop down tailgate versus the full hinge up Traveler tailgate. LST may still be visible on the glove box door. Or maybe he has a copy. That will tell you. I wouldn't rely on what the DMV has listed. In NY, they're not the brightest bulbs.
  5. Bigbt3
    Bigbt3 Farmall Cub
    Jan 8, 2014
    Yorktown
    It has a drop down tailgate. It must be a terra. It is actually my scout and I’m looking to sell it and didn’t know what the difference was between them. Thanks for the help.
  6. stroker3
    Feb 5, 2009
    3,660
    1,113
    Mass.
    If the LST isn't on the glovebox , for a very small amount you can order one to eliminate the guessing. All in all it's more about curiosity than anything else and it doesn't really mean a whole lot as far as running parts go.
  7. RinTX
    RinTX Binder Driver
    952
    119
    I have a Traveler and it has a regular Scout tailgate. Easy to change over. LST would be only way to know for sure what it left the factory as
  8. Howard Pletcher
    Howard Pletcher Farmall Cub
    Jul 23, 2007
    197
    41
    Fort Wayne, IN
    The fourth digit of the VIN will tell you which it was built as. A 9 was a Terra 4x4 and a 0 was a Traveler 4x4. Also, if it was a Terra with the bulkhead removed, there likely should be signs of where the mounting bolts went into the side panels.
    stroker3 likes this.
  9. Bigbt3
    Bigbt3 Farmall Cub
    Jan 8, 2014
    Yorktown
    Howard, 4th digit is a 9. It is a terra that’s been modified. Thank you for the knowledge.
  10. MrKenmore
    1,577
    216
    I guess if the fourth digit is a "7" it's a 2WD Terra!
  11. Howard Pletcher
    Jul 23, 2007
    197
    41
    Fort Wayne, IN
    Correct, and an 8 is a Traveler 4x2.
  12. MrKenmore
    1,577
    216
    Great info!
