1973 Travelall 1110 Overland/Expedition
Discussion in 'Binder Builds' started by ExpedTeeAll, Mar 9, 2020.
  1. ExpedTeeAll
    ExpedTeeAll Farmall Cub
    Feb 14, 2020
    19
    Mountain Boy.jpg This Travelall was christened "Mountain Boy" by a former girlfriend. Girlfriend is gone, "Mountain Boy" moniker remains. This is how the truck looked when I acquired it in winter 2019. It's a very clean example, almost rust free (no, really) and I think will make a great base for my build.
    My intention is to build an overland/expedition vehicle with moderate off-road capabilities but certainly not a rock crawler. I don't want a resto-mod setup, and hope to keep things looking mostly "original" with the exception of external accessories and lift. I also want to keep the 345 engine- if at all possible- but will consider (reluctantly) a future swap of an LS3 that I inherited. I intend to pull a small trailer behind, and hope to have decent pulling power with the EFI addition to the 345, but we will see. I live out of this Travelall and my RV- as in, full time living- so the rent money I save goes into the build since it's literally my home.
    I've listed below details of the truck when I acquired it, plus my build plans. I'll post progress and images in separate posts as I go. If you have suggestions don't hesitate to comment- I'm a Binder rookie on a steep learning curve and open to input.
    Vehicle as I acquired it:
    1973 Travelall 1110 4x4 - 59,xxx miles
    345 CID engine with 2bbl Holley 2210 carb
    727 Torqueflite 3-Speed Auto
    3.73 gears
    2 speed transfer case
    Rear Dana 44 axle (original??) 5 x 5.5 lug
    Rear drum brakes
    Original interior
    Known Modifications by previous owner(s):
    Front axle swap (yet unidentified) 5 3/8" wider than rear (??)
    Front disc brakes with 6 x 5.5 lug
    Front Custom bumper
    33 x 10.5 x 15 BFG A/T tires - cracked and disintegrating
    15 x 7 steel wheels (6 lug front, 5 lug rear) ??
    Auxiliary passenger side fuel tank and manual switch - doesn't work
    Possible suspension mods - seriously sagging
    Midas shocks- completely blown
    Edlebrock fuel pump - failed second day driving
    White spray-over paint - nice work
    MY BUILD PLANS for "Mountain Boy" and STATUS:
    MECHANICAL:
    Hamilton EFI full conversion - PARTS ORDERED, WAITING ON DELIVERY
    Fuel tank selector switch - WAITING ON ABOVE
    Dual rear quarter panel fuel tanks rebuild - IN PROGRESS
    Rear Axel swap to match front
    Front diff gasket
    Power brake conversion
    Power steering conversion - PARTS ORDERED
    Transmission swap with overdrive
    4.10 gear change - depending on towing experience
    Locking diffs (suggestions?)
    Engine rebuild (evaluate after EFI install)
    SUSPENSION, WHEELS, AND TIRES:
    CPT Front GM shackle conversion - COMPLETED
    Skyjacker 2.5" lift springs - COMPLETED
    Bilstein 5125 Shocks - COMPLETED
    BF Goodrich A/T K02 Tires 295/75R16 -HAVE PARTS
    Pro Comp Series 51 Steel Wheels - AS ABOVE
    5 x 5.5 to 6 x 5.5 Adapter to correct lug pattern and rear axle width - HAVE PARTS
    ELECTRICAL:
    Wiring harness replacement - ORDERED
    Heavy duty alternator
    USB dash plug
    Dual batteries
    Ravelco security kill switch - AFTER ECU INSTALL AND NEW WIRING HARNESS
    INTERNALS:
    Weather stripping - HAVE PARTS
    Headliner
    Overhead lighting
    Rear slide-out drawers
    Internal LUND 48" lockbox - COMPLETED
    EXTERNALS:
    Rustproof and under-spray
    Rhino Rack Pioneer Roof Rack - COMPLETED
    Rhino Rack Batwing Awning - COMPLETED
    Hi-Lift jack and roof mounts
    Rhino Rack rooftop spare tire straps
    Kuat NV 2.0 hitch mount bike rack - COMPLETED
    FSR 55" rooftop tent
    Rhino Rack double jerry can roof carrier
    Rhino Rack shovel carrier
    Exterior lighting
    Rear Swing-away spare tire mount
    Small overland trailer
  2. mongocanfly
    mongocanfly High Wheeler
    Nov 5, 2017
    1,412
    951
    Alabama
    Welcome to binders....WOW..!!...that is a nice one from the pic you showed....
    most likely you have a Chevy axle in the front...either dana44 or Corp 10bolt...a pic of the axle will help identify...
    Since the axles dont match, make darn sure the gear ratios are the same...
    More pics..more pics...
    and please hit the full size button when you load your pics...makes them easier to see..
    And if your gonna eventually add a od trans you'll need to work your gear ratios around that and tire size along with cruise speed...
    You made mention of a possible LS3 in the future...be aware that it can get expensive to wind up with a pass side drop transfercase...unless you can source a 4l80/np241 to go behind it...those came in 91 3/4t burbs..
    You sure wouldnt have any towing problems with a LS3 though...
    ExpedTeeAll and scout2000 like this.
  3. ExpedTeeAll
    Feb 14, 2020
    19
    Thanks! I changes the image to full size. I had the gears checked by wheel turning method- all seemed to spin the same. Here's the axle shots - and you can see the old front springs and how they were so sagged you can see where the u-bolts were hammering the frame.. I also need to change the rear diff gasket looks like.
    Here's the rear end- I assume Dana 44?:
  4. mongocanfly
    Nov 5, 2017
    1,412
    951
    Alabama
    Front axle is Corp 10bolt....those front ubolts are way to long...if nothing else just cutem off for now..unless you need the extra length later..
    Rear does appear to be dana44
    When you space those rear tires out be sure to check for tire rub with suspension articulation...may be real close to rubbing without the lift...
  5. winchested
    3,005
    1,052
    Yup corporate 10 bolt. So you could source a Chevy dana 44 or a corp 12 bolt to make the rear match. Or get a better front Chevy Dana 44 front and convert to ford rotors and spindles to get the 5x 5.5 pattern.
    ExpedTeeAll likes this.
  6. ExpedTeeAll
    Feb 14, 2020
    19
    As I understand, if I change the rear a 10 bolt is easier to find and cheaper than a 12 bolt, is this correct? I plan to tow up to about 6500 lbs. Is there any advantage to 12 bolt for towing? Do I need a truck specific axle when looking or is there no difference? I think they swapped the front to get the disk brakes ...I think, and I like the wider stance.
  7. mongocanfly
    Nov 5, 2017
    1,412
    951
    Alabama
    Go with a 12bolt....they're still available..if you get lucky you might find one with a locker already in it..
    A rear axle is gonna be a couple inches narrower than a front anyway..but measure your front axle from wms to wms..thatl give you an idea ...but I'd look for a axle from a square body Chevy truck..
  8. winchested
    3,005
    1,052
    10 bolts are the junk of the Chevy world from what I've been told to steer clear of them. You want a reliable overland rig then put the money into it now don't cheap out.
    Chris Cooper likes this.
  9. java230
    java230 Farmall Cub
    Jul 16, 2019
    241
    41
    That looks clean!
  10. Chris Cooper
    Chris Cooper Binder Driver
    Mar 11, 2018
    572
    191
    Longmont, CO
    That is a really nice truck. Can’t wait to see how this unfolds.
  11. MrKenmore
    MrKenmore Y-Block King
    3,144
    988
    Why not find a 3/4 ton GM and get the 14 bolt corporate and a 10 bolt up front? You will likely need to weld up spring perches and shock mounts but it a robust way to go.
  12. 2Dog-log
    2Dog-log Farmall Cub
    148
    32
    Baker City, OR.
    Awesome! I saw that for sale on ebay a while back. Loved it. Post lots of pictures of your progress!
  13. Darrel
    4,191
    767
    Nice find that's a sharp truck.
    GM truck 10 bolt front axles are almost identical in strength to vintage Dana 44's. Did you check that the axle ratios match? 3.73s are a great ratio for 33s, but as heavy are you'll be it'll struggle going up I-70. EFI won't give you any more power than a correctly tuned carb.
    Wheel adapters are prone to failure so make sure you're meticulous with the installation and re-torque regularly.
    Do you already have your collector plates or are you outside the emissions testing area?
  14. ExpedTeeAll
    Feb 14, 2020
    19
    I'm outside the emissions testing area. I hope the EFI does better than the failing 2210 carb I have now, but I'm primarily making the change because I tend to travel across big swings in elevation- sea level to 12,000ft in a few days is not uncommon for me. I did check the ratios- at least by turning all 4 wheels on a lift. Do you think I'll struggle up I70 (good litmus test road, btw) without a trailer?
  15. ExpedTeeAll
    Feb 14, 2020
    19
    DUEL TANK REBUILD
    Got the rear fuel tanks out. They both look good internally- the stock is getting boiled now and I ordered a new sending unit. I flushed the aux (aluminum) tank- and trying to figure out if I need to re-plumb the 1/4 return connection on top for 5/16- or whether 1/4 is good enough for EFI return line. Everything else with be 3/8 lines. I've decided to simply go with the 6-way switch and continue with the dual tank setup, so I'll have to find a universal sending unit and gauge the Aux side separately. Here's what they looked like:
    Stock side:
    And the auxiliary side:
    Removed both tanks and did as much as possible to remove the accumulated rust and dirt (used Rust-oleum rust remover gel- worked nicely). I'm surprised at how little rust was in there after clean-up ...the vast majority was light surface rust. I read on BP that rust inside the rear quarter panels are typically a weak spot for Travelalls.
    Before cleanup:
    After clean up:
    Aux side before:
    After:
    Both tanks before boil/flush:
    Next is a coat of primer plus a layer of undercoating inside the quarter panels for increased rust protection.
    Just finished the undercoat. Now waiting on the new sending units:
    java230 likes this.
  16. Darrel
    4,191
    767
    It'll struggle some. At 11000 ft a 345 only puts out 140bhp and Travelalls weigh over 5000 lbs before cargo, fuel, passengers. With 33s you can drop it into 2nd on the hwy if needed. Get a good trans cooler.
    Next time you pull apart the 10 bolt check your axle shaft size. Or check the tube for the date code stamp. Earlier models used 28 spline instead of 30 spline.
  17. RinTX
    1,948
    558
    Those wells are surprising. That is amazingly clean and rust free.
  18. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,414
    392
    Fresno,Ca
    Can you show how they did the auxiliary tank filler on the outside?
  19. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,414
    392
    Fresno,Ca
    Passenger side, where the spare tire went.
  20. Big Ed
    Big Ed High Wheeler
    Sep 29, 2010
    2,414
    392
    Fresno,Ca
    You don’t have this tank?
