1970 International Scout engine identification
Discussion in 'General IH Tech' started by Cody K, Nov 24, 2006.
  1. Cody K
    Cody K Farmall Cub
    Nov 24, 2006
    burleson, tx
    a freind of mine has a 1970 International scout we honestly do not know what motor is in it, we suspect it is a 1971 304ci motor but thats just what we suspect is there any easy way for us to identify if it is in fact a 304 international? and if it turns out that it is a 304 what is its oil capacity? the engine in it now has a distributor up front with a motorcraft 2 barrel carb....any ideas? thnx
  2. Greg R
    5,174
    788
  3. thescoutman67
    thescoutman67 Farmall Cub
    Jun 12, 2006
    wss, wv
    If You look above your fuel pump there will be a flat smooth space right above it scrape off the grease and dirt and it wil say v-304 v-345 or v-392,all IH V8 distributors are in the front. and a motocraft carburetor is compatable with IH intake manifolds.
    sincerely
    Thomas Taylor
  4. Cody K
    Cody K Farmall Cub
    Nov 24, 2006
    burleson, tx
    hey thnx man i'll take a look we really apriciate it
  5. Bburgessl
    Bburgessl Farmall Cub
    Jan 10, 2016
    12
  6. Bburgessl
    Jan 10, 2016
    12
    Mine says 4445, what is that
  7. kevingweq
    kevingweq Y-Block King
    Nov 1, 2013
    3,213
    810
    Royalston
    The number is not above the fuel pump , Well kinda :1eye: but it is stamped in the block below the head to the left of the fuel pump on the SV8 engines
  8. Gary Kitchens
    Gary Kitchens Farmall Cub
    Sep 20, 2017
    Hey guys a client just brought me a 70 maybe it's a 71 International pickup with a nice red V8 in it and the portion where you say the engine number is located is simply a flat machined surface even after my wire wheel there has never been anything stamped there so can you give me another idea on how to identify this motor?
  9. Gary Kitchens
    Sep 20, 2017
    20170920_151749.jpg Here's a photograph of the area in question 20170920_151637.jpg 20170920_151338.jpg
  10. kevingweq
    Nov 1, 2013
    3,213
    810
    Royalston
    the dipstick tube bracket has 2 holes , Take note of which hole the bolt is in on your engine
    Lower deck engines 266/304 will have bolt in lower hole of bracket
    Taller deck engines 345/392 will have bolt in upper hole of bracket
    Sometimes the cylinder heads have raised numbers cast in them 304/345 etc
    There is also an intake manifold measurement to distinguish 266-304/ 345-392
    I don't remember the particulars though.
    Maybe someone with more info can pin it down further
  11. mallen
    mallen Y-Block King
    3,713
    940
    What about the part number of the I take manifold. I don't recall where it's cast, but I know I saw one, and that will narrow it down. Also,if it has a 4bbl, then it's either a 392 or 345.
  12. Gary Kitchens
    Sep 20, 2017
    Thank you Kevin I'm pretty sure this is the original 304 but I'm going to do a stroke test tomorrow and I will check the location of that dipstick mount
    Sent from my SM-G930V using Tapatalk
