1966 IH Travelall update
Discussion in 'Binder Builds' started by Chade, Jan 5, 2017.
  1. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Made numerous changes to my 2WD Travelall. Sorry guys but the 304 needed to go so I could upgrade to a GM SBC and 5 speed tranny. Also removed the old rearend and installed a 1990 Iroc Z rearend with discs and posi trac unit. Monte Carlo front discs with a 9" double diaphragm booster. GM steering column and Ford Truck power steering and steering linkage. I know it's a Frankenstein but it should have all the amenities I want as a daily driver. Also planning on pulling my camper for local camping. IMG_3525.JPG [​IMG] IMG_3531.JPG [​IMG]
  2. punjig
    punjig Farmall Cub
    Sep 19, 2012
    285
    116
    Henderson, NV
    Looking nice. I like the guage setup and wheel. It may be a Frankenstein that is all personal taste and also depends on what you need out of it. Me, I am a IH fan and think they should maintain original power, BUT I'm also realistic and these builds. Hell, I think we all are. That is why we put Fuel Injection and other upgrades on them. I will be subscribing to your Build and look forward to the updates.
    The "Project Double D's" Garage
  3. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Yeah the IH equipment is great. But my wife wanted a minivan and she settled for a Travelall lol! The 3 speed on column just wasn't doing it for her. So now I have to modernize it to keep her in it! Darn the bad luck! Lol
    Thanks!
  4. jeff campbell
    15,380
    1,515
    looks great ! NICE, what ever to make HER happy ! them 3 speed column shift pretty much turned to junk after 30 years, was nice new, but when they get wore out, not so good.
  5. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Yeah the upgrades for the Travelall's just aren't there. Added the power steering from a Ford Truck. Booster is a GM and bolts up easily. Wiper motor is from a 99-00 dodge truck. Small modification there too![​IMG][​IMG]
    BajaIH likes this.
  6. bindermike
    bindermike Farmall Cub
    Apr 6, 2003
    253
    Lorton, VA
    Chade,
    What GM steering column did you use? It looks like a tilt with no ignition key on the column. How difficult was the conversion?
    Thanks, Mike
  7. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    The column conversion was fairly easy. I used a 30" but it was just barely long enough. Use a 32" like this.
    https://www.ebay.com/itm/122167357190
    You will have to require your turn signals and hazard lights. I haven't done that yet but don't expect to have a major problem once the Travelall is color coded.
  8. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Bindermike with the column I installed a 68-79 Ford power steering box. I used all the steering linkage and tie rod ends as well. You would have to taper the steering arms to match the tie rod ends if you go that route. Manual gearbox is mounted direct to the original column.
  9. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Well it's up and running strong! GM SBC with the NV4500 5 speed trans makes it a nice ride! 4 wheel discs and posi rear differential. Man this is a different car.
  10. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
  11. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
  12. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
  13. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Randall Barringer likes this.
  14. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
  15. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    Made a 3 hour pull on the Travelall and got 12mpg. I was extremely satisfied.
  16. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
  17. Chade
    Chade Farmall Cub
    Jun 4, 2016
    44
    This wiper motor fits the same bracket as the old international motor mounted. You will have to modify the shaft (key it) because the new motor is a taper shaft. Mine works fine, I just didn't wire it for low/high speed. It's either on or off.
