1966 1100A serial number location
Discussion in 'Triple Diamond Trucks' started by sarookha, Sep 20, 2017.
  1. sarookha
    sarookha Farmall Cub
    Dec 18, 2014
    382
    24
    Alba, Texas
    Here's the deal, there is a sweet 1966 1100A 4X4 for sale locally. No data plate, but the seller has a clear title that at least matches the truck's year. My 1954 R-130 has the serial number stamped on the frame, driver's side, between the front spring shackles. The 1100A frame is clean, clear, and not a mark on it anywhere I can see on the drivers side frame. The passenger side frame member has a 4 digit stamp up near where the bumper attaches, but that's all I can find. Those four digits don't match anything on the title.
    The frame seems to be original, because the 304, tranny, and transfer case are all mounted in what appears to be a factory install. No goofy fabbed mounts, it all looks right. The axles may not be original though, the hubs aren't big-six, and the front locking hubs aren't IH.
    I've run a title check with the Texas DMV, and the serial number on the title is still registered with the current seller. So if the data plate was grabbed by someone to register another stolen vehicle, they obviously didn't register it in Texas.
    I've applied for a LST with Super Scout Specialists. It's my understanding from other posts here on BP that with the title and the LST, I can order a new data plate sticker from any light line dealer.
    Is there anything I'm missing here? Does anyone know where the serial number is on the 1966 frames?
  2. kevingweq
    kevingweq High Wheeler
    Nov 1, 2013
    2,961
    606
    Sudbury Mass
    My 67 T-all serial number was partially hidden by the steering box bracket (will see if i can find pic)
  3. Jeff Jamison
    6,458
    415
    1100 is a 1/2 ton truck.would be 5 bolt wheels with internal style locking hubs.
  4. sarookha
    Dec 18, 2014
    382
    24
    Alba, Texas
    And the truck in question has 8 bolt hubs...
  5. sarookha
    Dec 18, 2014
    382
    24
    Alba, Texas
    @kevingweq, thanks, I'll check closer in that location. I think the steering box on the truck in question may not be original, so it may obscure the number.
  6. Jeff Jamison
    6,458
    415
    8 bolt is not factory for sure,has been changed.
  7. Gringo Gomez
    Gringo Gomez Farmall Cub
    May 7, 2015
    62
    Lawrenceville, NJ
    My '68 has the number near that location.
    Not obscured but lightly stamped & very difficult to read.
  8. Marcus English
    Marcus English Farmall Cub
    May 22, 2018
    I'm new to all this as I'm 16 and just bought my first project international (1966 travelette 1300a 4x4). I'm applying for a title and can't find a vin. In this picture is that the entire serial number or is there more to it than just those few letters and numbers?
    Thanks!
  9. Gringo Gomez
    May 7, 2015
    62
    Lawrenceville, NJ
    I can't see anything in that picture other than that is the proper location.
    I haven't looked at mine lately but IIRC, what is stamped on the frame is only the last six digits of the "VIN".
    Which as I understand it is actually a "model code/serial number" - e.g. "283208 H828959"
  10. Marcus English
    May 22, 2018
    Are the first 6 digits on the first portion of the "283208 H828959" what's on the block then? Sorry if this is a stupid question...
    Sent from my Pixel using Tapatalk
  11. Gringo Gomez
    May 7, 2015
    62
    Lawrenceville, NJ
    "828959" is stamped on the frame near the steering box. That is the "chassis" serial number.
    The engine serial number (another six digits that are not part of the "model code/serial number") should be stamped on the block.
    There are no stupid questions.
    Look on the edge of the driver door near the latch for the ID plate.
    That will have what you are looking for and more.
  12. Marcus English
    May 22, 2018
    Thanks for the info! I wasn't sure if the engine serial number was part of the sequential serial number. This international is much more simple than I'm making it I guess.
  13. Gringo Gomez
    May 7, 2015
    62
    Lawrenceville, NJ
    Welcome aboard. It gets better.
