1934 C 1 parts sources sought please help!
Discussion in 'Triple Diamond Trucks' started by CACornPicker, Mar 3, 2020.
  1. CACornPicker
    CACornPicker Farmall Cub
    Jul 7, 2003
    31
    Riverside California
    I'm looking for brake system parts for a 1934 C 1 barn find.
    Ran well when parked in 1979!
    Now it needs master and wheel cylinders, and various hoses.
    I imagine some of you have faced this and have some awesome tips about what modern things will substitute!
    I also need a couple of stock wire wheels, and the normal expendables such as fuel pump, carburetor kit, tune up parts, etc.
    Maybe even an engine gasket set, just in case.
    It does turn over. And it looks excellent inside the pan, transmission, and rear end..
    :banana:
  2. George Yingst
    George Yingst Farmall Cub
    Oct 16, 2007
    435
    33
    Deer Park, Wa.
    According to all the books I have read, 1936 was the first year for hydraulic brakes. I would suspect that is what you have regardless of what year it is titled as.
    No idea where to source parts from however...good luck.
  3. Dana Strong
    5,530
    1,345
    If no such new units are available, the old castings could probably be bored and sleeved. If needed, internal parts like pistons can be machined from bar stock or cast, using the lost wax process, perhaps modifying them a bit to work with modern rubber parts. Finding replacement original-dimension rubber parts might be a greater challenge, depending on how they differ from modern parts.
    For members who've worked on such old vehicles, good pictures might go far in letting them know better what you'd be replacing. Casting numbers, if any exist, might also be useful in internet searches.
