  #531
Old 07-26-2012, 06:27 PM
Default Re: CREWzer CAB TRANSPLANT
I have a lens in my hand Guide 5942303 B4-54.There are a few small chips on a section of the edge about 1/2 inch long,I also have housing and chrome ring(no gaskets)Pm or email if interested
  #532
Old 07-30-2012, 01:54 PM
sparkydog's Avatar
sparkydog sparkydog is offline
Thanks to Jeff I now have a backup light lens!
I still need metal inner door liners as shown in the photo 2 posts ago! Thanks for reading.
No matter where you go - there you are. No matter where you are - there you go!
Project Crewzer Cab
  #533
Old 07-31-2012, 09:07 AM
sparkydog's Avatar
I've been thinking about gauges for the dash. Here is a pic of where I'm at. A 5" speedo in the middle and a 3-3/8 on either side. One a tach and the other a 4 in 1. So far so good. Autometer makes just what I want. But then I start to get into the details and it all blows up on me.
My first issue is I don't want an 8k or 10k tach. I would like a 6k or even a 4k tach because my cruiser is never gonna see north of about 3k rpm. My second issue is I HATE friggin 2-digit tachometers. I want a 1-digit tach so that it is butt-simple for my little brain to look down at the dash and not confuse my speed with my engine rpm.
Wanting a 6k rpm tach rules out Autometer. But the brands that do offer a 6k tach (like VDO) don't have the 4 in 1's. And apparently I am weird in my quest for a single digit tach because again not many vendors make these and those that do - don't seem to have the 4 in 1 or they don't have the larger sizes.
Does anybody have any suggestions?
Project Crewzer Cab
  #534
Old 08-01-2012, 10:26 AM
jemarshall64's Avatar
jemarshall64 jemarshall64 is offline
Send a message via MSN to jemarshall64
Give this a look.
http://www.dakotadigital.com/index.c...d=664&mode=cat
Jon Marshall
1980 Traveller SD33T/T19/D300
77 terra 196 727/203/D300, SOA, 35's, Propane, bobbed & pinched
And alot of parts rigs
  #535
Old 08-13-2012, 09:57 PM
sparkydog's Avatar
I drove her to Oregon and back this past week and finally had a chance to check gas milage. My best was Fresno to Redding where I did 19.2 mpg at about 65 average (due to lots of construction zones). Even my first tank was over 17 and that was with 2 days of commute and then LA and over the Tejon pass.
I stopped in Redding to check out some different wheels and ended up buying them. They are still Mustang lug pattern and using my wheel adapters to compensate for the deeper back spacing. But their net offset is now more like the stock GM wheels so the steering is better and I like the Cragar style look.
Project Crewzer Cab
  #536
Old 08-28-2012, 04:34 PM
sparkydog's Avatar
This past weekend I added a front bumper to the truck. I did a mockup with the GMC bumper that came with the Z71 X cab. I liked what it did enough to go buy the same bumper but without trim at a wrecking yard. The two bumpers were harvested to make the one I needed. Here are some progress shots.
Project Crewzer Cab
  #537
Old 08-28-2012, 04:36 PM
sparkydog's Avatar
And many hours later.. the almost finished product! I will be extending the ends of the corners so that they line up with the wheel opening in the fenders. And the finish welding. And the strip off of the old chrome. And the new chrome. Details, details, details.
But I have to say I like the result. This bumper has a simplistic shape which might have come out of the IH assy line in the late 60's. But it also has a slightly modern look so it does a good job of blurring the lines between new and old.
Project Crewzer Cab
  #538
Old 08-29-2012, 09:03 AM
gmbarker78's Avatar
gmbarker78 gmbarker78 is offline
That bumper looks right at home, may have to rob that idea at some point.
67 800 Limited GRC Edition, 266/T-19W/D300
79 Terra Rallye, mostly stock driver
61 Travelette, KOH Chase inspired build...........one day!
1250 Cub Quietline
  #539
Old 09-10-2012, 09:25 AM
sparkydog's Avatar
A couple of small items.
Thanks to Jeff here on Binder Planet forum I was able to get a glass lens for my backup light and put the lenses and rings back on after 2 years.
Then I figured out how to adapt the sun visors out of the GM into the truck. I had to cut and paste the mounting bosses because the IH cab ceiling is a little narrower and more rounded than the GM cab. As usual my welds are ugly but functional.
Project Crewzer Cab
  #540
Old 09-10-2012, 02:19 PM
sparkydog's Avatar
I extended the ends of the bumper tips so they would blend with the line of the wheel opening better. I also welded up 6 holes that were in the bumper. Then I ran out of flapper wheels.
Project Crewzer Cab
2wd , axle , body , broke , build , efi , front , gear , ignition , mount , pickup , pictures , power , project , rear , rear axle , replacement , sale , start , steering , top , travelall , travelette , truck , tug
Pics of my new Cab and journey! Brad T Triple Diamond Trucks 8 01-02-2009 10:11 PM
Cab lights/no cab lights j calavera General IH Tech 7 10-26-2007 03:45 PM
1310 Cab Travails Hooper General IH Tech 0 12-07-2003 12:07 AM
1310 Body Mount Bolts Hooper General IH Tech 8 06-05-2003 11:14 AM
80/800 Half Cab ?'s RonG General IH Tech 3 03-16-2003 04:50 PM
